E*Thirteen trs + espec TRS Plus 11-speed 9-46 teeth - auch für E-bike geeignet
Artikelbeschreibung: E*Thirteen trs + espec TRS Plus 11-speed 9-46 teeth - auch für E-bike geeignet
Biete diese wenig genutzte (Max 50km) 11-Fach Kassette an.
neupreis bei bike-components ist aktuell bei 183,99 EUR
/en/e-thirteen/TRS-Plus-11-speed-Cassette-p72637/
[center]The TRS Plus 11-speed cassette by e*thirteen is stable and also fits your e-bike[/center]
The TRS Plus 11-speed cassette by e*thirteen is extremely durable and thus also suitable for use on e-bikes. Unlike the previous model, the cassette consists of more steel and fewer aluminium sprockets, which makes it more durable. TRS Plus cassettes have always offered more range, more value and less weight than the competition.
Guidelines for Replacing E-bike Components:
Before you replace components on your e-bike, please read through the guidelines for component replacement for CE-marked e-bikes/pedelecs with pedal assistance.
Specifications:
Application:
Cross Country, Trail, All Mountain, Enduro, E-Bike
Gearing:
11-speed
Gradation:
9-46
Sprocket Material:
steel (sprockets 1 to 10), aluminium (sprocket 11)
Freehub Compatibility:
SRAM XD
Note:
To use the TRS Plus cassette on Hope hubs you need a shim. Not compatible with Shimano drivetrains.
Technical Information:
Series:
TRS Plus
Spider:
2 (1 x steel, 1 x aluminium)
Features:
  • 511% range
  • 2-part design allows aluminium and steel cluster to be exchanged separately
  • faster shifting
  • improved durability
  • new installation system eliminates the need for proprietary tools, only 3 mm hex wrench required
  • compatible with SRAM systems
Models:
9-46:
  • Gradation: 9-10-12-14-17-20-24-28-33-39-46 T
  • Manufacturer Number: FW2TPA-101
Contents:
  • 1 x e*thirteen TRS Plus 11-speed cassette
  • 1 x bushing
  • 1 x 3 mm set screw
  • 1 x 3 mm pinch bolt
  • 1 x grease
  • 1 x decal
Weight:
  • black/9-46: 390 g
Manufacturer:
e*thirteen
1120 Harold St
Alameda
CA 94501
USA
E*Thirteen trs + espec TRS Plus 11-speed 9-46 teeth - auch für E-bike geeignet kaufen
125 €
Details & Spezifikationen : E*Thirteen trs + espec TRS Plus 11-speed 9-46 teeth - auch für E-bike geeignet
Anzahl 1
Hersteller E*Thirteen
Zustand gebraucht, wie neu
Versandkosten 7 €
Land Deutschland de
Abholung Ja
Gewicht 390
Farbe Schwarz/Silber
Ketten-/Schaltungstyp 11-fach
Gänge 11
Angesehen 326 ×
Momentane Betrachter 1
Veröffentlicht 4. Mai 2025 17:57
Endet 4. Mai 2026 17:57
