Hope Tech 3 V4 Duo - Silver, weitere Farben möglich
419,99 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: Hope Tech 3 V4 Duo - Silver, weitere Farben möglich
The Tech 3 Duo Master cylinder is aimed to people wanting to operate individually 2 calipers from one single hand.
Description
The master cylinder is combined with either our X2, E4 or V4 calipers will suit any riding for XC to Enduro/All mountain to DH.
The design is derived from the proven Tech 3 master cylinder and with the finger reach and bite point adjustments on each lever, you can be sure the levers will feel comfortable and suit your riding style. The Tech 3 Duo Master differs from our Uno system as there is a total independency between the front and rear calipers.
  • Two V4 calipers
  • 2 independent circuits for safe operation
  • Tech 3 lever offers genuine bite point and reach adjustment without tools
  • V4 caliper uses 2x16mm and 2x18mm phenolic pistons to give more usable power
  • Uses post mount, 9.74 caliper with adapters to suit all mount options
  • CNC machined from 2014 T6 aluminium alloy
  • Top entry pad fitting
  • Shimano I-Spec A shifters can be fitted directly to lever body
  • Separate direct mounts also available for Shimano I Spec 2, I-Spec EV & Sram shifters
  • Anodized for durability
  • Compatible with a wide range of rotors from 160mm to 220mm.
Pflichtangaben nach GPSR
Herstellerinformationen (außerhalb EU)
Hope Mill Calf Hall Road Barnoldswick Lancashire BB18 5PX Vereinigtes Königreich info@hopetech.com
Weitere Angaben sind eventuell in den Produktbildern enthalten.
Hope Tech 3 V4 Duo - Silver, weitere Farben möglich kaufen
419,99 €
sm-bikes de Gewerbliche/r Anbieter*in
Antwort in: 4 h
Bewertungen: 958 (100%)
Vertrauen: 20
Details & Spezifikationen : Hope Tech 3 V4 Duo - Silver, weitere Farben möglich
Anzahl 1
Hersteller Hope Tech
Hersteller-Informationen (falls nicht in EU ansässig) Hope Mill Calf Hall Road Barnoldswick Lancashire BB18 5PX Vereinigtes Königreich info@hopetech.com
Zustand neu
Land Deutschland de
Abholung Nein
Akzeptierte Bezahlmethoden PayPal, Überweisung
Angesehen 177 ×
Momentane Betrachter 1
Veröffentlicht 20. Jun 2025 21:48
Endet 20. Jun 2026 21:48
