Commençal Meta Power
Artikelbeschreibung: Commençal Meta Power
Kurbeln,shifter,Kassette,Kette,Antriebsritzel Neu. 2x Akku, 2x Ladegeräte (schnellladeherät)Specs
FRAME2020 META Power 29 (integrated battery), 160 mm travel
29'', Alloy 6066, triple butted tubes, T4, T6. Enduro bearings
SYSTEMSHIMANO E8000
250 W, 70 Nm
BATTERYSHIMANO E8035
504 Wh
DISPLAYSHIMANO E8000
SHOCKROCKSHOX SuperDeluxe Ultimate
230 x 60 mm, low speed compression, rebound, lockout
FORKROCKSHOX Lyrik Ultimate RC2, 170 mm travel
29", Charger 2.1 damper, Debonair, low speed / high speed compression, rebound, Boost (15 x 110 mm), 51 mm offset
HEADSETACROS Alloy cups ZS44/ZS56
ZS44/ZS56, sealed bearings
STEMRIDE ALPHA Freeride, 50 mm
31,8 mm, 0° angle, 2014 alloy
BARRIDE ALPHA, 20 mm rise, 780 mm, 31,8 mm
7050 alloy, double butted
GRIPSRIDE ALPHA, DH Grips, black
Ultra soft compound, single clamp
BRAKESSRAM Code RSC, 200 mm / 200 mm
4 pistons
SHIFTERSSRAM GX Eagle, 12 sp, Single click
CHAIN GUIDERIDE ALPHA 34t
Shimano Steps specific
REAR MECHSRAM XO1 Eagle, 12 sp
Red
BOTTOM BRACKETSHIMANO
CRANKSSHIMANO XT E8050, 165 mm
Hollowtech
RINGSRAM X-SYNC EAGLE, 34t
CHAINSRAM GX Eagle, 12 sp
118 links
CASSETTESRAM GX Eagle, 12 sp
10-50t
RIMSDT SWISS H1700 Spline
32 holes, 30.5 mm inner width, tubeless ready
HUBSDT SWISS H1700 Spline
32 holes, 6 bolts, 15 x 110 mm front, 12 x 148 mm rear, XD freehub body
SPOKES / NIPPLESDT SWISS
TYRESSCHWALBE Magic Mary, 29x2.35 / SCHWALBE Magic Mary, 29x2.35
Super Gravity, Addix Soft compound / Super Gravity, Addix Soft compound
SEATPOSTKINDSHOCK Lev Integra
31.6 mm, Southpaw alloy lever, 125 mm on S, 150 mm on M, 175 mm on L and XL
SADDLEFABRIC Scoop Flat Elite
Team Edition, crmo rails
WEIGHT23,5 kg / 51.8 lbs
PEDALS INCLUDEDYes
COLOURBoxxer Red / Chalk grey
Shiny clear coat
ACCESSORIESRIDE ALPHA CNC Alloy pedals, motor protector, chainstay protector, seatstay protector, battery charger, user manual
META POWER bikes are delivered with Shimano Europlug (CEE 7/7 norm) battery charger, a plug adapter is necessary for customers living in countries using different standards.
BATTERY RECYCLINGpartnership with SHIMANO
In partnership with SHIMANO, COMMENCAL supports a voluntary battery recycling program for ebike batteries. For each META POWER sold COMMENCAL will contribute 7EUR to fundraising organisation COREPILE. This sum is paid through SHIMANO France. When your battery reaches the end of its life, it would be great if you could send it back to us for recycling. Contact us for more info on the procedureTECH
Tech
BICYCLE TYPEE-bike Enduro 29"
FRAME MATERIALAL-6061 + AL-6066
FRAME WEIGHT-
REAR TRAVEL160 mm
SHOCK LENGTH / STROKE230 x 60 mm
PIGGY BACK SHOCK COMPATIBLEYes
SHOCK BUSHINGS20 x 10 mm front / 12,7 x 10 mm rear
RECOMMENDED / MAX. FORK HEIGHT571 mm / 581 mm
HEADSET DIMENSIONTapered
HEADSET TYPEZS44 / ZS56
MAXIMUM TYRE DIMENSION (ETRTO)65 mm - 622
DISC BRAKE STANDARD Postmount 160 mm
REAR ROTOR MAX. SIZE220 mm
SEATPOST / SEAT CLAMP DIAMETER31,6 mm / 34,9 mm
BOTTOM BRACKET TYPESHIMANO
ISCGYes (SHIMANO Standard)
FRONT DERAILLEUR TYPENo
REAR HUB COMPATIBILITY12 x 148 mm, Maxle standard
automatisch übersetzt
Loading translation, one moment please …
Commençal Meta Power kaufen
1.999 €
Details & Spezifikationen : Commençal Meta Power
Anzahl 1
Hersteller Commençal
Modell Commencal Meta Power
Zustand gebraucht
Abholung Ja
Ort Zürich - Schweiz
Rahmengröße L
Federweg vorn 170 mm
Federweg hinten 160 mm
Dämpfer-Einbaumaße 190 x 40 mm Metric
Laufradgröße 29"
Material Aluminium
Gänge 12
Angesehen 1.145 ×
Momentane Betrachter 1
Veröffentlicht 28. Aug 2025 12:41
Endet 28. Aug 2026 12:41
