Unno Mith PRO 2026 (S3)
Fotos: Unno Mith PRO 2026 (S3)
11.000 €
Artikelbeschreibung: Unno Mith PRO 2026 (S3)
Selling a new and unused Unno Mith PRO in size S3 (180-195cm).
Has 0km and is ready for it's first owner!
WIth invoice and warranty.
All components original and listed below.
For more information message me.
COMPONENTS:
Frame
Carbon fiber monocoque with 160 mm of rear travel. Virtual pivot suspension system. Integrated display, battery, chain guide, and seat tube clamp. Motor protector. EnduroMAX bearings. Internal cable routing. Boost thru-axle 12x148. Post Mount brake system.
Fork
Fox 38 Factory, 170 mm travel. Kashima coating. GRIP X2 damper. Adjustments: HSC, LSC, HSR, LSR. 44 mm offset.
Rear Shock
Fox Float X2 Factory, 230x65 mm. Kashima coating. 2-position lever. VVC rebound. Adjustments: HSC, LSC, HSR, LSR.
Motor
DJI Avinox drive unit weighing 2.52 kg with:
Power output:
Battery
DJI Avinox 800 Wh integrated battery (3.74 kg). Comes with a fast charger. Charges from 0–100% in 2 hours 25 minutes.
Display & Remote
DJI Avinox 2” OLED smart multifunction touchscreen, 800 nits brightness, 326 ppi.
DJI dual wireless controllers with Bluetooth connectivity.
Shifter
SRAM AXS Pod Controller Rocker Paddle
Rear Derailleur
SRAM X0 Eagle AXS T-Type, 12-speed. AXS wireless. T-Type.
Cassette
SRAM X0 T-Type XS-1295. 12-speed. 10–52T.
Chain
SRAM X0 T-Type, 120 links. Flattop. 12-speed.
Crankset
E13 Helix Core e*spec, 155 mm
Chainring
UNNO 36T
Handlebar
OneUp V2 Carbon handlebar, 35 mm diameter, 800 mm width, 35 mm rise
Stem
OneUp 42 mm stem
Headset
ACROS Block-Lock 135° with Cane Creek spacers
Saddle
Fizik Terra Aidon X5, 145 mm
Seatpost
OneUp V3 Mechanical dropper post. 180 mm travel, 31.6 mm (reduces to 22.2 mm at actuator)
Brakes (Front | Rear)
SRAM Maven Silver
Wheelset
DT Swiss HXC 1700 Mullet — 29” front / 27.5” rear
Tires (Front | Rear)
Schwalbe Magic Mary Ultra Soft, Gravity Pro, TLR, 29” x 2.5”
Schwalbe Magic Mary Soft Evo, Gravity Pro, TLR, 27.5” x 2.5”
COMPONENTS:
Frame
Fork
Rear Shock
Motor
- 70 Nm (Eco)
- 105 Nm (Auto, Trail, Turbo)
- 120 Nm (Boost)
Power output:
- 250 W (rated)
- 850 W (peak)
- 1000 W (maximum)
Battery
Display & Remote
Shifter
Rear Derailleur
Cassette
Chain
Crankset
Chainring
UNNO 36T
Handlebar
Stem
OneUp 42 mm stem
Headset
Saddle
Seatpost
SRAM Maven Silver
Wheelset
automatisch übersetzt
Unno Mith PRO 2026 (S3) kaufen
11.000 €
Verkäufer RyanMtb
5/5
basierend auf 5 Bewertungen.
Details & Spezifikationen : Unno Mith PRO 2026 (S3)
| Anzahl | 1 |
| Hersteller | Unno |
| Zustand | neu |
| Land |
Slowenien |
| Abholung | Nein |
| Rahmengröße | L |
| Dämpfer-Einbaumaße | 190 x 40 mm Metric |
| Laufradgröße | 26" |
| Angesehen | 488 × |
| Momentane Betrachter | 1 |
| Veröffentlicht | 4. Feb 2026 18:36 |
| Endet | 4. Feb 2027 18:36 |
