Commençal Meta Power
Artikelbeschreibung: Commençal Meta Power
* RAHMEN
META POWER SX V4, 165 mm travel
29"-27.5", Alloy 6066, triple butted tubes, T4, T6.
* MOTOR
BOSCH Performance Line CX
Max. torque: 85N.m, 250W
* AKKU
BOSCH PowerTube 625, 625Wh
BOSCH 4A Charger, Compact size & lightweight
Compatible w/BOSCH PowerMore 250 for extra range
* DISPLAY
BOSCH System Controller
BOSCH Mini Remote currently not available in the USA
* DÄMPFER
ROCKSHOX Super Deluxe Ultimate
230 x 65 mm, DebonAir +, RC2T damper HSC, LSC, rebound, 2-position compression (open/firm) 1 Token neg. 0 Token pos.
* GABEL
ROCKSHOX Zeb Ultimate, 170 mm travel
29", DebonAir+ W/ ButterCups, Charger 3 RC2 W/ ButterCup damper, LSC, HSC, rebound, Boost (15 x 110 mm), 44 mm offset, 1 Token
* STEUERSATZ
ACROS ZS56 / ZS66
Alloy cups, sealed bearings
* VORBAU
Title ST1 35mm, 35mm extension
OneUp tool
* LENKER
Tilte FORM 35 - 780mm
* GRIFFE
ODI Longneck
Soft compound, single clamp, black
* BREMSEN
TRP DH-R Evo, 4 pistons, resin pads
Rotors: TRP R1 223/220 mm, 6-bolt, 2.3 mm width
* SCHALTUNG
SRAM POD - Rocker
* KETTENFÜHRUNG
RIDE ALPHA Upper Guide
32-34t
* SCHALTWERK
SRAM GX AXS Eagle 12speed + charger
* KURBEL
N
E13 E*Spec Plus BOSCH CX, 160 mm crank arms
Chainring: E13 E*Spec Plus BOSCH CX, 34t, direct mount
* KETTE
SRAM GX Eagle
12s
* KASSETTE
SRAM NX ebike
* FELGEN
Rear: DT SWISS HX1700 Spline - Front: DT SWISS HX1700 Spline
Rear: 27.5'', 28h, 30 mm inner width - Front: 29'', 28h, 30 mm inner width
* NABEN
Rear: DT SWISS 350 - Front: DT SWISS 350
Rear: 28h, 12 x 148 mm, sealed bearings, e-bike specific, HG freebody - Front: 28h, 15 x 110 mm, sealed bearings
* SPEICHEN / NIPPEL
DT SWISS Hybrid 1
Straightpull, 2.34/2.0mm, double butted, stainless, with ProLock, black
* REIFEN
Rear: SCHWALBE Big Betty - Front: SCHWALBE Magic Mary
Rear: 27.5" x 2.4", Super Trail, Addix Soft, Tubeless Easy - Front: 29" x 2.4", Super Trail, Addix Soft, Tubeless Easy
Tubeless + insert in rear
* SATTELSTÜTZE
KS Lev Integra 31.6 mm, travel: 175 mm
Rockshox Reverb AXS 150mm €
* SATTEL
Ergon SM e-Mountain
* GEWICHT
24.3 kg / 53.57 lbs
Average weight for S size, without pedals. Weight may differ slightly due to manufacturing tolerances.
* FARBE
Chalk
Shiny Finish
Ride wrap frame protection
Pedale werden nicht mit verkauft.
Rockshox Reverb AXS kann für 300€ mit verkauft werden. Alternativ ist KS Lev Integra enthalten.
Bei Fragen etc. gerne jederzeit melden :)
automatisch übersetzt
Loading translation, one moment please …
Commençal Meta Power kaufen
5.490 € VHB
Details & Spezifikationen : Commençal Meta Power
Anzahl 1
Hersteller Commençal
Modell Commencal Meta Power
Zustand gebraucht, wie neu
Abholung Ja
Ort Frauenneuharting
Gewicht 25
Farbe Grau
Rahmengröße M
Federweg vorn 170 mm
Federweg hinten 165 mm
Steuerrohr Tapered 1⅛″/1,5″
Dämpfer-Einbaumaße 190 x 40 mm Metric
Laufradgröße Mullet 29" / 27,5"
Material Aluminium
Gänge 12
Angesehen 487 ×
Momentane Betrachter 1
Veröffentlicht 13. Aug 2026 07:05
Endet 13. Aug 2027 07:05
