RockShox Lyrik Charger 2 RC2 + Vorsprung Smashpot coil kit
700,00 € VHB
Momentane Betrachter
4
Veröffentlicht
24.09.2019 20:52
Endet
24.09.2020 20:52
Angesehen
403 ×
Anzahl
Hersteller
RockShox
Zustand
gebraucht
Abholung
Nein
Bg
Gabelschaft
Tapered
Federungstyp
Stahlfeder
Federweg
180
Laufradgröße
27,5" / 650b
Nabenbreite vorn
110 mm
Achsdurchmesser Vorderrad
15 mm
Händler
Nein
Land
Bulgarien bg
Akzeptierte Bezahlmethoden
PayPal
Verkaufe Gabel im Auftrag von einem Kumpel ...
I'm selling RockShox Lyrik Charger 2 RC2 with Vorsprung Smashpot coil sprung kit.
It's 27.5, Boost 15x110mm, at the moment is set to 180mm travel, but you can internally adjust it from 150 to 180 whit spacers included. Steerer tube is 19cm long.
Its fully serviced at 06.09.2019, all the seals, oils, o-rings, seal head, dust wipers are brand new. Just jump and ride, no investments needed.
Stanchions in perfect shape, no stone chips, no hits.
Lowers, normal sings of use, one minimal dent on the bottom, but no technical problem, visual only. You can see on the photos.
Always used only Sram greases and oils for services.
The Smashpot is coil sprung system whit speed sensitive bottom out control. You can adjust it as firm as you like. It's crazy supple over small to medium bumps, supportive at the middle stroke and ramps up as much as you need at the end stroke. No temperature changes in the damping as whit air spring, consistent and reliable. The 50 hour service became 75+ hour, because of the high amount of oil in the left leg and no seals to create friction.
The fork in this configuration is an absolute beast. But my new fork is 29" so have to sell it.
Currently is whit 50lbs spring. I'm 75 kilos whit no gear, and around 80kg with gear. So the 50lbs spring gives me 25% sag, which is perfect.
I'm also including 60lbs spring if you are a heavy rider.
Before all the questions about the performance or price of the Smashpot, you better google it :)
Preis incl Versand
Verkauf von privat, ohne Garantie und Gewährleistung.
Zahlung per Paypal (an Freunde), oder +3%
Versand erfolgt per DPD mit Traking. Da aus Bulgarien, dauert erfahrungsgemäß 3-5 Arbeitstage.
Avatar
Bewertungen:
80 (100,0 %)
Verkäufer outfaced Verkäufer outfaced
5/5 basierend auf 80 Bewertungen.
Vertrauen: 1
Antwort in: 46 min
Fragen zum Artikel
Du kannst dem Verkäufer hier eine Frage zum Artikel stellen. Er kann diese dann an dieser Stelle beantworten. Fragen und Antworten sind öffentlich sichtbar.
