Specialized EPIC PRO LTD
Fotos: Specialized EPIC PRO LTD
6.500 €
VHB
Artikelbeschreibung: Specialized EPIC PRO LTD
EINZELSTÜCK - NAGELNEU - Traumbike in Rose
RAHMEN
FACT 11m Full Carbon, Progressive XC Race Geometry, Rider-First Engineered™, threaded BB, 12x148mm UDH compatible rear spacing, internal cable routing, 100mm of travel
SATTELSTÜTZKLEMME
Specialized Alloy, 34.9mm
SWAT
SWAT Box, Bottle cage EMT Tool cradle
GABEL
RockShox SID SL ULTIMATE BRAIN, Top-Adjust Brain damper, Debon Air, 15x110mm, 44mm offset, 110mm Travel
DÄMPFER
RockShox-Specialized BRAIN, Rx XC Tune, 5 Position Platform Adjust, Rebound Adjust, Integraded Extension, 265x52.5mm
SATTELSTÜTZE
Bike Yoke Divine SL, 30.9mm, SM: 100/ MD-XL: 125mm,
SATTEL
Body Geometry Power Expert
LENKER
S-Works Carbon XC Mini Rise, 6-degree upsweep, 8-degree backsweep, 10mm rise, 760mm, 31.8mm
VORBAU
Specialized Pro SL, alloy, 4-bolt
Grips
Specialized Trail Grips
BREMSE VORNE
SRAM Level Silver Stealth, 2-piston caliper, hydraulic disc, 160/180mm rotor
BREMSE HINTEN
SRAM Level Silver Stealth, 2-piston caliper, hydraulic disc, 160mm rotor
SCHALTHEBEL
SRAM AXS POD Controller
INNENLAGER
SRAM DUB Threaded Wide
KETTE
SRAM XO Eagle Flat top
SCHALTWERK
SRAM X0 Eagle AXS
KURBELGARNITUR
SRAM XO Eagle Crankset With Spindle Power meter, 170mm/175mm, 34t chainring
KASSETTE
SRAM XO Eagle 10-52t
KETTENBLÄTTER
34T
HINTERRADNABE
DT Swiss 350 straight-pull, 6-bolt, DT Swiss Ratchet EXP, 12x148mm thru axle, XD freehub body, 28h straight-pull
VORDERRADNABE
DT Swiss 350, 6-bolt, 15mm Thru-axle, 110mm spacing, 28h straight -pull
SPEICHEN
DT Swiss Comp Race
VORDERREIFEN
Specialized Fast Trak, Control Casing, T7 Compound, 29x2.35
HINTERREIFEN
Specialized Renegade, Control Casing, T5 Compound, 29x2.35
FELGEN
Roval Control, Carbon offset design, 29mm internal width, 4mm hook width, Tubeless ready, 28h
SCHLÄUCHE
Specialized Turbo Tube
Privatverkauf; keine Garantie/Gewährleistung oder Rücknahme
RAHMEN
SATTELSTÜTZKLEMME
SWAT
GABEL
DÄMPFER
SATTELSTÜTZE
SATTEL
LENKER
VORBAU
Grips
BREMSE VORNE
BREMSE HINTEN
SCHALTHEBEL
INNENLAGER
KETTE
SCHALTWERK
SRAM X0 Eagle AXS
KURBELGARNITUR
KASSETTE
KETTENBLÄTTER
34T
HINTERRADNABE
VORDERRADNABE
SPEICHEN
DT Swiss Comp Race
VORDERREIFEN
HINTERREIFEN
FELGEN
SCHLÄUCHE
automatisch übersetzt
Specialized EPIC PRO LTD kaufen
6.500 €
VHB
Details & Spezifikationen : Specialized EPIC PRO LTD
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Epic |
Zustand | neu |
Land | Deutschland |
Abholung | Ja |
Ort | Würzburg |
Gewicht | ~ 10,5 kg |
Rahmengröße | S |
Federweg vorn | 110 mm |
Federweg hinten | 110 mm |
Dämpfer-Einbaumaße | Sonstige |
Laufradgröße | 29" |
Material | Carbon |
Gänge | 12 |
Akzeptierte Bezahlmethoden | PayPal, Überweisung |
Angesehen | 372 × |
Momentane Betrachter | 1 |
Veröffentlicht | 23. Mai 2024 15:01 |
Endet | 23. Mai 2025 15:01 |
