Commençal Meta AM 29 frame - XL
Fotos: Commençal Meta AM 29 frame - XL
Artikelbeschreibung: Commençal Meta AM 29 frame - XL
I am selling a Commencal Meta AM 29 frame in size XL. It’s a great carefree enduro bike that pedals well despite its higher weight thanks to the steep seat angle.
The frame was replaced by Commencal last year in September after a crack on the front frame triangle. Since then I've ridden about 1200km. In contrast to the original 2021 Meta AM, this frame has a flip chip in the yoke that allows you to adjust the geometry. (0,5° steeper, 5mm longer)
The bike is completely covered with Ridewrap film. The film shows signs of wear and tear in the usual areas. The frame itself has no dents or major scratches in the paint. See photos!
Included in the price are the Rock Shox Select air shock (original from 2022) and the Oneup Dropper V2 with 240mm drop built into the frame. I have an inseam of approx. 93cm with a height of 191cm. The 240 should be rideable to an inseam of approx. 91cm - then you can shorten it by another 20mm if needed. Headset is from hope, bottom bracket from shimano (both new in Sep. 2023) I will gladly include a few new bearings for the rear triangle. (not a complete bearing set)
The RockShox Super Deluxe Ultimate Coil 2023 230x62,5 installed in the frame in the photos was installed in the frame in February 2024. It was ridden approx. 600km - so it is as good as new. With the HBO, the shock fits the bike very well despite the frame being relatively linear. I also had a progressive Sprindex spring installed, I can recommend it, it’s a dream! I would like to have € 300 for the shock. Not selling the sprindex though.
Frame with air shock, dropper, headset: 750€
Coil shock: + 300€
This is a private sale and guarantees and warranties are excluded.
Shipping is generally no problem for an extra charge - I would of course prefer collection.
Coil shock: + 300€
automatisch übersetzt
![QR-Code zum Teilen des Angebots](/qr/item/1724/1724307.png)
Commençal Meta AM 29 frame - XL kaufen
750 €
Details & Spezifikationen : Commençal Meta AM 29 frame - XL
Anzahl | 1 |
Hersteller | Commençal |
Modell | Commencal Meta AM |
Zustand | gebraucht |
Abholung | Ja |
Ort | Graz- Österreich |
Farbe | Origin Grey |
Rahmengröße | XL |
Federweg vorn | 170 mm |
Federweg hinten | 160 mm |
Steuerrohr | Tapered 1⅛″/1,5″ |
Steuerrohr-Länge | 125 mm |
Dämpfer-Einbaumaße | 230 x 65 mm Metric |
Laufradgröße | 29" |
Material | Aluminium |
Angesehen | 202 × |
Momentane Betrachter | 1 |
Veröffentlicht | 24. Jun 2024 11:48 |
Endet | 24. Jun 2025 11:48 |
