Specialized S-Works Turbo Levo Modell 2024 Neu und originalverpackt Fabrikneu
Fotos: Specialized S-Works Turbo Levo Modell 2024 Neu und originalverpackt Fabrikneu
9.900 €
Artikelbeschreibung: Specialized S-Works Turbo Levo Modell 2024 Neu und originalverpackt Fabrikneu
Zum Verkauf steht ein neues, ungefahrenes, originalverpacktes, Akku originalverpackt ohne Ladezyklen, fabrikneues
Specialized S-Works Turbo Levo S4
inkl. Originalrechnung aus Reklamationsawicklung.
Specialized Artikelnr.: 95223-0204
Technische Spezifikationen:
E-BIKE
MOTOR
Specialized 2.2 Custom Rx Trail Tuned Motor
DISPLAY
Specialized MasterMind TCU, percentage of remaining charge, 120 possible display configurations, MicroTune assist adjustment, ANT+/Bluetooth®, w/Handlebar remote
AKKU
Specialized M3-700, Integrated battery, 700Wh
LADEGERÄT
Custom charger, 42V4A w/ Rosenberger plug, 100-240V
KABELBAUM
Custom Specialized wiring harness
Fahrwerk
DÄMPFER
Fox Float X2 Factory, Kashima, 210x55mm
Rahmenset
RAHMEN
FACT 11m full carbon, 29" front wheel, 27.5" rear wheel, full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel, geo adjust head tube, geo adjust horst pivot
GABEL
2023_22, 38, K, FLOAT, 29in, F-S, 160, Grip 2, HSC, LSC, HSR, LSR, Shiny Blk, CQV M701S Over SBC K13 Nearly Black Gloss/SBC K01 Logo, Kabolt-X 110, BLK, 1.5 T, 58HT, 44mm Rake, N/M OE
SATTELSTÜTZKLEMME
Alloy, 38.6mm
Cockpit
SATTEL
Bridge, 155/143mm, Hollow Ti-rails
SATTELSTÜTZE
RockShox Reverb AXS, 30.9, 1X remote, (S1:100mm, S2: 125mm, S3: 150mm, S4-S6: 170mm)
VORBAU
Deity, 35.0mm
LENKER
Roval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm, 35.0mm
LENKERGRIFFE
Deity Grips
Bremsen
BREMSE VORNE
SRAM Code Stealth Ultimate, 4-piston caliper, hydraulic disc, 220mm rotor
BREMSE HINTEN
Antrieb
SCHALTWERK
SRAM XX Eagle Transmission Derailleur
SCHALTHEBEL
SRAM AXS POD Controller
KASSETTE
SRAM XX Eagle Transmission Cassette, 12spd, 10-52t
KETTE
SRAM XX Eagle Transmission Flattop Chain
KURBELGARNITUR
Praxis Carbon/Custom Offset/ISIS Spindle Interface, 160mm
KETTENBLÄTTER
New SL 1.2 spider, 104BCD w/SRAM 32t Transmission compatible alloy ring
Laufräder
VORDERRAD
Roval Traverse SL 29
HINTERRAD
Roval Traverse SL 27.5, 148mm spacing, XD freehub body
VORDERREIFEN
Butcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.6"
HINTERREIFEN
Eliminator, GRID TRAIL casing, GRIPTON® T7 compound, 2Bliss Ready, 27.5x2.6"
SCHLÄUCHE
Standard, Presta Valve
Accessories
Pedals
PEDAL, TEST RIDE PEDALS PROVIDED BY SPECIALIZED
SWAT
SWAT CC steerer tube integrated tool with chain tool and link
Weight
Weight
22.5kg (49 lb, 9.7 oz)
Weight Size
S4
Radkarton wird bis zum ersten Besichtigungstermin oder Verkauf nicht angerührt um die Exklusivität zu wahren.
Das Rad stammt aus einer Garantieleistung original von Specialized da mein vorheriges S-Works Levo einen Schaden am Rahmen hatte.
Das Rad wurde heute 04.06.24 zu meinem Händler geliefert und ist bisher absolut unangetastet genau so wie es von Specialized/Spedition kam.
Aufgrund des hohen Verkaufswerts würde ich ganz klar eine Abholung und Begutachtung als Abwicklung begrüßen, um eine gewisses Vertrauen für den Käufer zu schaffen.
Versand ist aber grundsätzlich auch möglich.
Standort Esslingen oder 73072
Die offizielle Reklamations Rechnung vom Händler liegt vor.
Privatverkauf eventuelle Gewährleistungsansprüche sind an den Hersteller zu richten.
Rad wird als fabrikneu verkauft.
E-BIKE
MOTOR
DISPLAY
AKKU
LADEGERÄT
KABELBAUM
Fahrwerk
DÄMPFER
Rahmenset
RAHMEN
GABEL
SATTELSTÜTZKLEMME
Alloy, 38.6mm
Cockpit
SATTEL
SATTELSTÜTZE
VORBAU
Deity, 35.0mm
LENKER
LENKERGRIFFE
Deity Grips
Bremsen
BREMSE VORNE
BREMSE HINTEN
Antrieb
SCHALTWERK
SCHALTHEBEL
KASSETTE
KETTE
KURBELGARNITUR
KETTENBLÄTTER
Laufräder
VORDERRAD
HINTERRAD
VORDERREIFEN
HINTERREIFEN
SCHLÄUCHE
Accessories
Pedals
SWAT
Weight
Weight
Weight Size
S4
automatisch übersetzt
![QR-Code zum Teilen des Angebots](/qr/item/1724/1724824.png)
Specialized S-Works Turbo Levo Modell 2024 Neu und originalverpackt Fabrikneu kaufen
9.900 €
Verkäufer bike1502
5/5
basierend auf 129 Bewertungen.
Details & Spezifikationen : Specialized S-Works Turbo Levo Modell 2024 Neu und originalverpackt Fabrikneu
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Turbo Levo |
Zustand | neu |
Versandkosten | 80 € |
Land |
Deutschland |
Abholung | Ja |
Ort | 73072 |
Gewicht | 22,4kg |
Farbe | Gloss Black Liquid Metal / Satin Black Chrome Foil |
Rahmengröße | L |
Motor | Brose |
Akku-Kapazität | 700 Wh |
Federweg vorn | 160 mm |
Federweg hinten | 150 mm |
Steuerrohr | Tapered 1⅛″/1,5″ |
Dämpfer-Einbaumaße | 210 x 55 mm Metric |
Laufradgröße | Mullet 29" / 27,5" |
Material | Carbon |
Gänge | 12 |
Angesehen | 219 × |
Momentane Betrachter | 1 |
Veröffentlicht | 28. Jun 2024 10:31 |
Endet | 28. Jun 2025 10:31 |
