Specialized Stumpjumper S-Works Evo 2024 S4 T-Type
Fotos: Specialized Stumpjumper S-Works Evo 2024 S4 T-Type
6.000 €
Artikelbeschreibung: Specialized Stumpjumper S-Works Evo 2024 S4 T-Type
Nur wenige Monate gefahrenes Bike in Top Zustand! Wenige Gebrauchsspuren
Wurde auf full 29" umgebaut
27.5 Link zum Umbau auf Mullet erhältlich mit Aufpreis
/ch/en/s-works-stumpjumper-evo-t-type/p/224676?color=366407-224676
Technical Specifications
Frameset
Frame
FACT 11m carbon chassis and rear-end, asymmetrical design, 29 Trail Geometry, SWAT™ Door integration, head tube angle adjustment, horst pivot BB adjustment, threaded BB, fully enclosed internal cable routing, 12x148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm of travel
Seat Binder
Alloy, 38.6mm
Suspension
Rear Shock
FOX FLOAT X2 Factory, Rx Trail Tune, 2-position open/firm lever, HSC, LSC, HSR, and LSR adjustment, S2-S6:210x55mm " oder Vivid Air
Fork
FOX FLOAT 36 Factory, GRIP2 damper, 15x110mm, 44mm offset, S1: 150mm of travel, S2-S6: 160mm of travel
Cockpit
Saddle
Bridge, 155/143mm, Hollow Ti-rails
SeatPost
RockShox Reverb AXS, 30.9, 1X remote, (S1:100mm, S2: 125mm, S3: 150mm, S4-S6: 170mm)
Stem
OneUp Stem, 35mm bar bore
Handlebars
OneUp Carbon, riser bar, 5-degree upsweep, 8-degree backsweep, 35mm rise, 800mm, 35.0mm
Grips
Deity Lockjaw
Brakes
Rear Brake
SRAM Code Ultimate Stealth, 4-piston caliper, hydraulic disc, 200mm HS2 Rotor
Front Brake
Drivetrain
Rear Derailleur SRAM XX Eagle Transmission Derailleur
Shift Levers SRAM AXS POD Ultimate Controller
Cassette SRAM XX Eagle SL Transmission Cassette, 12spd, 10-52T
Chain SRAM XX Eagle SL Transmission Flattop Chain, 12spd
Crankset SRAM XX Eagle, Carbon, with Aluminum Guards, DUB, 32T, S2-S5: 170mm
Chainrings 32T
Bottom Bracket SRAM DUB WIDE, BSA 73mm, Threaded
Wheels & Tires
Rims Roval Traverse 29 HD Carbon, 30mm internal width, 28h: Roval Traverse 27.5 HD Carbon, 30mm internal width, 32h
Front Hub DT Swiss 240, 28h, 15x110
Rear Hub DT Swiss 240, 32h, 12x148
Spokes DT Swiss Aerolite
Tires: Cannibal Grid Gravity front & rear
Weight
14.34kg (31lb, 9.8 oz) Weight Size S4
Frameset
Frame
Seat Binder
Alloy, 38.6mm
Suspension
Rear Shock
Fork
Cockpit
Saddle
SeatPost
Stem
Handlebars
Grips
Deity Lockjaw
Brakes
Rear Brake
Front Brake
Drivetrain
Chainrings 32T
Wheels & Tires
Weight
automatisch übersetzt
Specialized Stumpjumper S-Works Evo 2024 S4 T-Type kaufen
6.000 €
Verkäufer caro_gehrig
4/5
basierend auf 28 Bewertungen.
Details & Spezifikationen : Specialized Stumpjumper S-Works Evo 2024 S4 T-Type
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Stumpjumper |
Zustand | gebraucht, wie neu |
Versandkosten | 50 € |
Land | Schweiz |
Abholung | Ja |
Ort | |
Rahmengröße | L |
Federweg vorn | 160 mm |
Federweg hinten | 150 mm |
Dämpfer-Einbaumaße | 210 x 55 mm Metric |
Laufradgröße | 29" |
Material | Carbon |
Gänge | 12 |
Angesehen | 2.030 × |
Momentane Betrachter | 1 |
Veröffentlicht | 5. Aug 2024 21:28 |
Endet | 5. Aug 2025 21:28 |
