Specialized Stumpjumper 15 Fox Coil Alloy 2025 NEU
Fotos: Specialized Stumpjumper 15 Fox Coil Alloy 2025 NEU
5.300 €
VHB
Artikelbeschreibung: Specialized Stumpjumper 15 Fox Coil Alloy 2025 NEU
Nagelneues Modell, Stumpjumper 15 in Größe S4(L). Rad ist noch im Karton und ungeöffnet. Bestellbar mit Rechnung und Garantie. Für weitere Informationen schreib mir!
Rahmenset
SWAT
SWAT internal downtube storage
RAHMEN
M5 Alloy chassis and rear-end, Trail Geometry, SWAT Door integration, head tube angle adjustment, threaded BB, internal cable routing, 12x148mm dropouts, sealed cartridge bearing pivots, SRAM UDH compatible, 145mm of travel
SATTELSTÜTZKLEMME
Alloy, 38.6mm
Fahrwerk
DÄMPFER
FOX DHX Factory, Ride Dynamics Trail Tune, 210x55mm, S2: 400lbs, S3: 450lbs, S4: 500bs, S5: 550lbs, S6: 600lbs
GABEL
FOX FLOAT 38 Factory, GRIP X2 damper, HS and LS rebound and compression adjustment, 15x110mm QR axle, 44mm offset, 160mm of travel
Bremsen
BREMSE VORNE
TRP DH-R EVO, 4-piston caliper, hydraulic disc, 220mm
BREMSE HINTEN
TRP DH-R EVO, 4-piston caliper, hydraulic disc, 203mm
Antrieb
SCHALTHEBEL
Shimano SLX, M7100, 12spd
SCHALTWERK
Shimano SLX, M7100, SGS, 12-speed
KASSETTE
Shimano SLX, CS-M7100, 12-speed, 10-51t
KETTE
Shimano SLX, M7100, 12-speed
KURBELGARNITUR
Shimano SLX, M7120, 32T ring, 55mm chainline, S2-S3:165mm, S4-S6: 170mm
INNENLAGER
Shimano, BB-MT801, Threaded
Laufräder
FELGEN
Roval Traverse, hookless alloy, 30mm inner width, tubeless ready, Front: 29, Rear: 27.5
VORDERRADNABE
DT Swiss 370, 15x110mm, 28h
HINTERRADNABE
DT Swiss 370, 12x148mm, 32h
SPEICHEN
Sapim Force
VORDERREIFEN
Butcher, GRID TRAIL casing, GRIPTON T9 compound, 2Bliss Ready, 29x2.3"
HINTERREIFEN
Eliminator, GRID GRAVITY casing, GRIPTON T9/T7 compound, 2Bliss Ready, 27.5x2.3"
SCHLÄUCHE
Standard, Presta valve
Cockpit
VORBAU
Deity, 35mm clamp, 35mm length
LENKER
Deity, Racepoint, 5-degree upsweep, 9-degree backsweep, 810 width, S2: 25mm rise: S3-S6: 38mm rise
LENKERGRIFFE
Deity, Knuckleduster, Black
SATTEL
Bridge Comp, Hollow Cr-mo rails, S1-S2: 155mm, S3-S6: 143mm
SATTELSTÜTZE
PNW Loam OE Dropper, tool-less travel adjust, Range lever, 34.9, S2: 150mm, S3: 170mm, S4-S6: 200mm
Gewicht
GEWICHT
257786
GEWICHT
16.90 kg (37 lb, 4.1 oz)
GEMESSENE RAHMENGRÖSSE
S4
Rahmenset
SWAT
RAHMEN
SATTELSTÜTZKLEMME
Alloy, 38.6mm
Fahrwerk
DÄMPFER
GABEL
Bremsen
BREMSE VORNE
BREMSE HINTEN
Antrieb
SCHALTHEBEL
SCHALTWERK
KASSETTE
KETTE
KURBELGARNITUR
INNENLAGER
Laufräder
FELGEN
VORDERRADNABE
HINTERRADNABE
SPEICHEN
Sapim Force
VORDERREIFEN
HINTERREIFEN
SCHLÄUCHE
Cockpit
VORBAU
LENKER
LENKERGRIFFE
SATTEL
SATTELSTÜTZE
Gewicht
GEWICHT
257786
GEWICHT
S4
automatisch übersetzt
Specialized Stumpjumper 15 Fox Coil Alloy 2025 NEU kaufen
5.300 €
VHB
Details & Spezifikationen : Specialized Stumpjumper 15 Fox Coil Alloy 2025 NEU
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Stumpjumper |
Zustand | neu |
Land | Slowenien |
Abholung | Nein |
Rahmengröße | L |
Dämpfer-Einbaumaße | 190 x 40 mm Metric |
Laufradgröße | Mullet 29" / 27,5" |
Angesehen | 258 × |
Momentane Betrachter | 1 |
Veröffentlicht | 17. Sep 2024 21:52 |
Endet | 17. Sep 2025 21:52 |
