Specialized 2024 Specialized Turbo Levo S-Works S4 *NEU*
Fotos: Specialized 2024 Specialized Turbo Levo S-Works S4 *NEU*
7.999 €
VHB
Artikelbeschreibung: Specialized 2024 Specialized Turbo Levo S-Works S4 *NEU*
NUR NOCH BIS SONNTAG, 13. OKT VERFÜGBAR!
S-Works Turbo Levo Carbon E-Bike
Modell 2024, NEU direkt aus der Schachtel
Hersteller UVP € 13.500,-
Bike kommt mit Rechnung!
Größe S4
Angabe Specialized:
S4 entspricht Large für Körpergröße 173 -188cm
Gewicht
22.5kg - S4
FARBE
GLOSS GOLD PEARL OVER CARBON / CARBON / GOLD PEARL OVER CARBON
MOTOR
Specialized 2.2 Custom Rx Trail Tuned Motor
DISPLAY
Specialized MasterMind TCU, percentage of remaining charge, 120 possible display configurations, MicroTune assist adjustment, ANT+/Bluetooth, w/Handlebar remote
AKKU
Specialized M3-700, Integrated battery, 700Wh
LADEGERÄT
Custom charger, 42V4A w/ Rosenberger plug, 100-240V
KABELBAUM
Custom Specialized wiring harness
DÄMPFER
Fox Float X2 Factory, Kashima, 210x55mm
RAHMEN
FACT 11m full carbon, 29" front wheel, 27.5" rear wheel, full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel, geo adjust head tube, geo adjust horst pivot
SATTELSTÜTZKLEMME
Alloy, 38.6mm
GABEL
2023_22, 38, K, FLOAT, 29in, F-S, 160, Grip 2, HSC, LSC, HSR, LSR, Shiny Blk, CQV M701S Over SBC K13 Nearly Black Gloss/SBC K01 Logo, Kabolt-X 110, BLK, 1.5 T, 58HT, 44mm Rake, N/M OE
BREMSE VORNE
SRAM Code Stealth Ultimate, 4-piston caliper, hydraulic disc, 220mm rotor
BREMSE HINTEN
SCHALTHEBEL
SRAM AXS POD Controller
SCHALTWERK
SRAM XX Eagle Transmission Derailleur
KASSETTE
SRAM XX Eagle Transmission Cassette, 12spd, 10-52t
KETTE
SRAM XX Eagle Transmission Flattop Chain
KURBELGARNITUR
Praxis Carbon/Custom Offset/ISIS Spindle Interface, 160mm
KETTENBLÄTTER
New SL 1.2 spider, 104BCD w/SRAM 32t Transmission compatible alloy ring
VORDERRAD
Roval Traverse SL 29
HINTERRAD
Roval Traverse SL 27.5, 148mm spacing, XD freehub body
VORDERREIFEN
Butcher, GRID TRAIL casing, GRIPTON T9 compound, 2Bliss Ready, 29x2.6"
HINTERREIFEN
Eliminator, GRID TRAIL casing, GRIPTON T7 compound, 2Bliss Ready, 27.5x2.6"
SCHLÄUCHE
Standard, Presta Valve
SATTEL
Bridge, 155/143mm, Hollow Ti-rails
VORBAU
Deity, 35.0mm
LENKER
Roval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm, 35.0mm
LENKERGRIFFE
Deity Grips
SATTELSTÜTZE
RockShox Reverb AXS, 30.9, 1X remote, (S4: 170mm)
Pedals
PEDAL, TEST RIDE PEDALS PROVIDED BY SPECIALIZED
SWAT
SWAT CC steerer tube integrated tool with chain tool and link
Größe S4
Angabe Specialized:
Gewicht
22.5kg - S4
FARBE
MOTOR
DISPLAY
AKKU
LADEGERÄT
KABELBAUM
DÄMPFER
RAHMEN
SATTELSTÜTZKLEMME
Alloy, 38.6mm
GABEL
BREMSE VORNE
BREMSE HINTEN
SCHALTHEBEL
SCHALTWERK
KASSETTE
KETTE
KURBELGARNITUR
KETTENBLÄTTER
VORDERRAD
HINTERRAD
VORDERREIFEN
HINTERREIFEN
SCHLÄUCHE
SATTEL
VORBAU
Deity, 35.0mm
LENKER
LENKERGRIFFE
Deity Grips
SATTELSTÜTZE
Pedals
SWAT
automatisch übersetzt
Specialized 2024 Specialized Turbo Levo S-Works S4 *NEU* kaufen
7.999 €
VHB
Details & Spezifikationen : Specialized 2024 Specialized Turbo Levo S-Works S4 *NEU*
Anzahl | 1 |
Hersteller | Specialized |
Modell | Specialized Turbo Levo |
Zustand | neu |
Versandkosten | 50 € |
Land | Österreich |
Abholung | Ja |
Ort | |
Farbe | Gloss Gold Pearl Over Carbon / Carbon / Gold Pearl Over Carbon |
Rahmengröße | Other |
Motor | Specialized |
Akku-Kapazität | 700 Wh |
Federweg vorn | 160 mm |
Federweg hinten | 150 mm |
Dämpfer-Einbaumaße | 210 x 55 mm Metric |
Laufradgröße | Mullet 29" / 27,5" |
Material | Carbon |
Angesehen | 189 × |
Momentane Betrachter | 1 |
Veröffentlicht | 9. Okt 2024 13:34 |
Endet | 9. Okt 2025 13:34 |
