RockShox Reba 100mm Boost 1,5" Tapered
Fotos: RockShox Reba 100mm Boost 1,5" Tapered
Artikelbeschreibung: RockShox Reba 100mm Boost 1,5" Tapered
Verkaufe meine Reba 100 Boost wegen umstieg auf mehr Federweg.
Remote Controll ist dabei nur auf den Bildern nicht...
Schaftlänge 21cm
FS-REBA-10B-A9 - 14t14672513
Spezifikationen:
Model designator (SF)
RL
Wheel size
29"
Travel (mm)
100mm
Damper Type
Motion Control
Fork offset
51mm (29")
Maxle included
Maxle Lite
Color (FS)
Diffusion Black
E-Bike Approved
E-bike Approved w/E-MTB Decal
Steerer
1.5" Tapered
Axle
15x110mm BOOST™
Axle to Crown (mm)
506
Brake type (FD)
Disc
Crown Material
Forged, hollow aluminum
Upper crown type
n/a
Lower leg type
Magnesium
Upper Tube Finish
Fast Black
Upper tube type
32mm straight wall aluminum
Damper adjust
TwistLoc/OneLoc Remote (10mm cable pull – sold separately)
Damping adjustments
Extl rebnd, 2 pos remote comp (open/lock)
Volume reducer
0/3 Tokens
Spring
Solo Air
Spring rate
n/a
Max Tire Diameter (mm)
755
Max Tire Width (mm)
81
Maximum Rotor Size
220mm
Minimum Rotor Size
160mm
Fender Compatibility
n/a
Crown OD (mm)
53
Max recommended system weight
331lbs/150kg
Max Air Pressure (PSI)
195
Part Weight (g)
1638
Versand gegen Aufpreis möglich
Schaftlänge 21cm
Spezifikationen:
RL
Wheel size
29"
Travel (mm)
100mm
Damper Type
Motion Control
Fork offset
51mm (29")
Maxle included
Maxle Lite
Color (FS)
Diffusion Black
E-Bike Approved
Steerer
1.5" Tapered
Axle
15x110mm BOOST™
Axle to Crown (mm)
506
Brake type (FD)
Disc
Crown Material
Upper crown type
n/a
Lower leg type
Magnesium
Upper Tube Finish
Fast Black
Upper tube type
Damper adjust
Damping adjustments
Volume reducer
0/3 Tokens
Spring
Solo Air
Spring rate
n/a
755
Max Tire Width (mm)
81
Maximum Rotor Size
220mm
Minimum Rotor Size
160mm
n/a
Crown OD (mm)
53
331lbs/150kg
195
Part Weight (g)
1638
automatisch übersetzt
![QR-Code zum Teilen des Angebots](/qr/item/1726/1726899.png)
RockShox Reba 100mm Boost 1,5" Tapered kaufen
180 €
Details & Spezifikationen : RockShox Reba 100mm Boost 1,5" Tapered
Anzahl | 1 |
Hersteller | RockShox |
Modell | RockShox Reba |
Zustand | gebraucht, wie neu |
Versandkosten | 6,90 € |
Land |
Deutschland |
Abholung | Ja |
Ort | |
Länge Gabelschaft | 210 mm |
Federweg | 100 mm |
Gabel-Offset | 51 mm |
Laufradgröße | 29" |
Nabenbreite vorn | 110 mm |
Achsdurchmesser Vorderrad | 15 mm |
Gabelschaft | Tapered |
Akzeptierte Bezahlmethoden | PayPal, Überweisung |
Angesehen | 379 × |
Momentane Betrachter | 2 |
Veröffentlicht | 15. Jul 2024 08:20 |
Endet | 15. Jul 2025 08:20 |
