RockShox PIKE ULTIMATE RC2 29" DEBONAIR 150MM BOOST 15X110MM BLK
Fotos: RockShox PIKE ULTIMATE RC2 29" DEBONAIR 150MM BOOST 15X110MM BLK
449 €
Preis inkl. MwSt. und zzgl. Versandkosten
Die Versandkosten können erst berechnet werden, wenn du eingeloggt bist. Anmelden
Artikelbeschreibung: RockShox PIKE ULTIMATE RC2 29" DEBONAIR 150MM BOOST 15X110MM BLK
Federgabel
Mountainbike
Rock Shox Pike Ultimate RC2
Black Edition
29er
42mm Offset
150mm Federweg
15x110 Boost
HSC, LSC Ultimate Kartusche
Luftgabel - Debonair
Model 2021/22
Black
Labels Silver
Tapered ungekürzt 245mm
Einbauhöhe 565mm
Model designator (SF) Ultimate
Wheel size 29"
Travel (mm) 150mm
Damper Type Charger 2.1 RC2
Fork offset 42mm (29")
Maxle included Maxle Stealth
Color (FS) Gloss Black W/Rainbow Decal
E-Bike Approved E-bike Approved
Steerer 1.5" Tapered
Axle 15x110mm BOOST™
Axle to Crown (mm) 561
Brake type (FD) Disc
Crown Material Forged, hollow aluminum
Upper crown type n/a
Lower leg type Magnesium
Upper Tube Finish Fast Black
Upper tube type 35mm tapered wall aluminum
Damper adjust Crown
Damping adjustments Extl begin stroke rebnd, low speed comp, high speed comp
Volume reducer 1/4 Tokens
Spring DebonAir
Spring rate n/a
Max Tire Diameter (mm) 770
Max Tire Width (mm) 81
Maximum Rotor Size 220mm
Minimum Rotor Size 180mm
Fender Compatibility n/a
Crown OD (mm) 58
Max recommended system weight n/a
Preis 449.- statt 1099.-
Mountainbike
Black Edition
29er
42mm Offset
150mm Federweg
15x110 Boost
Model 2021/22
Black
Labels Silver
Einbauhöhe 565mm
Wheel size 29"
Travel (mm) 150mm
Damper adjust Crown
Spring DebonAir
Spring rate n/a
Crown OD (mm) 58
automatisch übersetzt
![QR-Code zum Teilen des Angebots](/qr/item/1730/1730012.png)
RockShox PIKE ULTIMATE RC2 29" DEBONAIR 150MM BOOST 15X110MM BLK kaufen
449 €
Verkäufer Deusmagnus
5/5
basierend auf 1217 Bewertungen.
Details & Spezifikationen : RockShox PIKE ULTIMATE RC2 29" DEBONAIR 150MM BOOST 15X110MM BLK
Anzahl | 1 |
Hersteller | RockShox |
Modell | RockShox Pike |
Zustand | neu |
Land |
Österreich |
Abholung | Ja |
Laufradgröße | 29" |
Gabelschaft | Tapered |
Akzeptierte Bezahlmethoden | Überweisung |
Angesehen | 311 × |
Momentane Betrachter | 1 |
Veröffentlicht | 11. Aug 2024 08:00 |
Endet | 11. Aug 2025 08:00 |
